Hey all, where is the expansion valve located? Pics or diagrams would be great. But a description is also welcome.
This AC is killing me. I bought this car knowing that the AC was an issue but I had no idea. When I put the gauges on it (1234yf) it was already in a vacuum. I put my pump on it for good measure for 30 minutes just because. After that I added some oil which was just enough to get the clutch to kick in. The system sucked in 1 and half 8oz cans. After that it would not take anymore, and the PSI on both the high and low sides were the same. So I replaced the compressor, and I got the same results. A guy I know that works on big building AC units suggested that I change the expansion valve. I'm getting ready to order it but I don't know where it is located.
If this doesn't work you all will hear me screaming in defeat as I take the car to the shop.
