I have recently purchased a 2018 Transit and it has 7000 miles on it. It was a salvaged vehicle with only bolt on parts damage. (Outta state) it has developed a shutter like driving over rumble strips. It is not all the time. When it gets bad it does it for about 5 seconds then stops for a couple then does it again. Other times it does a couple times a in a mile.
They have done so much to try to fix this issue and nothing yet, trans and torque converter change, drive shaft several times, opened up the rear diff and inspected it all, turned the rotors, balanced the tires, had it in to Ford and they trouble shot it and updated a couple things in the new trans and said the trans and torque converter check out fine.
The accident was front rt corner, bumber cover, hood, headlight and fender.
