Wife bought a new 2020 Ford Escape few months ago and the headlights fogged up. Took it back to the dealer and they put 2 new headlight assembles in and they done they same thing. Now their telling me Ford says that's the nature of them :( We're not going to let this go. They are worse now 1605835067453.png 1605835151968.png
This is a common occurrence on a lot of todays headlights , not just Ford but a lot of other makes also .From your owners manual ,
GENERAL INFORMATION
Condensation in the Exterior Front Lamps and Rear Lamps
Exterior front lamps and rear lamps have vents to accommodate normal changes in air pressure.
Condensation can be a natural by-product of this design. When moist air enters the lamp assembly through the vents, there is a possibility that condensation can occur when the temperature is cold. When normal condensation occurs, a fine mist can form on the interior of the lens. The fine mist eventually clears and exits through the vents during normal operation.
Clearing time may take as long as 48 hours under dry weather conditions.
Examples of acceptable condensation are:
  • The presence of a fine mist (no streaks, drip marks or large droplets).
  • A fine mist covers less than 50% of the lens.
Examples of unacceptable condensation are:
  • A water puddle inside the lamp.
  • Streaks, drip marks or large droplets present on the interior of the lens.
If you see any unacceptable condensation, have your vehicle checked by an authorized dealer.
