·Set off to town this morning and the clutch pedal went to the floor when I
changed gear at a T junction. I pulled the pedal up again with my toe and
it worked fine for a few more gear changes, then down to the floor again.
Stamping made no difference but lifting with the toe did and I was able to
change gears again.
No clutch fluid leaking out, inside or outside the vehicle, that I can see.
Clutch pedal return spring is fine.
Spoke to a few local gurus and the consensus seems to be clutch cylinders
but no decision as to which one, so I have ordered both on a sale or return
basis on the assumption that if one has gone the other will be sure to
follow.
At least it didn't happen at Dromochter!<g>
Derry
change gears again.
follow.
Derry
