1 - 20 of 40 Posts
Well, seeing that there are a few people out there planning stroker builds in the future, here's a thread for people to contribute to so that people don't get burned with dud expensive mismatching parts.
Please feel free to post combo part numbers, brands, suppliers, builders etc that you've found to work.
This will help everyones back pocket and time. Cheers. :hy:
1970 Torino GT 408C
Here is my 408C stroker motor I put together this winter.
I will list the specs. and pics. here, For anyone who is interested, tell me what you think.
I got the stroker kit from Mark & Heather McKeown of "MME Motorsports & Engineering".
4.00 stroke Lightweight 4340 forged Scat crank
6.200 Scat 4340 H beam rods with 7/16 Arp 2000 Rod Bolts
4.010 ROSS 13.75-1 ratio forged pistions
Pro Products Balancer
Scat Flexplate
(All this Balanced through 8000 RPM)
Ford Motorsports double roller timing chain
Custom grind - Comp Cams -- Specs by Mark Mckeown --
Duration at .050 272 In. 276 Ex.
valve lift .697 In. .668 Ex.
Harland Sharp 1.8 Aluminum roller rockers
Comp Cams Solid lifters with EDM oiling hole
The Block is a 1972 4 Bolt main block
The Heads are 1970 quench chambers, with Manley severe
duty 1 piece SS valves
Comp Cams double valve spring
10 degree valve locks and retainers
teflon seals
Heads have been machined for 7/16 screw in studs &
guide plates
Comp cams forged 1 piece pushrods
High volume oil pump
ARP oil pump drive shaft
stock CJ pan with baffle in bottom
Hooker headers 1 7/8" primarys 3' collectors
AED 1000CFM 4150 series Holley Carb
Torker intake
1/4 Berch wood carb. spacer
Holley mech. fuel pump with #8 line from pump to carb.
Fabricated aluminum sheet metal valve covers
aluminum water pump
74 XB Fairmont
This is a 393 cleveland kit that will fit into a 9.2" factory C block without issues. It's direct bolt in. Tony xa and I run this very kit.
Crank Scat 3.850 4340 forged crank part n# SC4351c 3850 6125
Be careful with this part number as if you change the 4 in the first part SC 4 351c to a 9 SC 9 351c you go to the 9000 series crank not as good . 3850 is for the crank 6125 is for rod length
Rods Scat h-beams part n# SC2350 6125 2100 these are large journal chev rods 6.125 Sc2350 is for 350 chev 6125 length 2100 journal size
Pistons Arias forged -10cc dished part n# AP331520
Timing chain SVO rollmaster red label part n# ROCS3110
Prices were removed as these will vary over time.
74 XB Fairmont
In my research I also found this from High Performance World. They do two stroker kits for the 351c factory deck block 9.200"
First one is 383ci with flat top .020/.030 Venolia race pistons, Eagle H-Beam rods, Eagle 4340 forged crank, Competition plazma moly rings & Competition bearings for $3000.00 Add $330.00 for dish pistons. This kit has a 6.000" conrod and will require some clearancing on the crank. If you want to use the 6.125" conrod, it will cost you an extra $160.00. When going to the longer rod, you will require oil support rails x 8 @ $120.00.
Second kit is 406ci same parts as above but will require the 6.125" conrods & the oil support rails. Cost is $3280.00 for flat top & $3610.00 for dish pistons. The kit requires a Rollmaster timing set to suit the Eagle crank $131.45 & a Romac neutral balancer $251.00 All prices include GST
Those prices were valid on 13/09/2005. Not sure if they are still valid?
For those about to use a 3.75 inch stroke with a 6.125 rod then Probe industries are as far as i know the only piston manufacturer who has an off the shelf piston that is specific for a clevo. Part no is 14212-030 for a 30 over piston but is available in 20 or 40 over. Comp height is 1.2 inches with 1/16 rings and comes with a .927 pin for the use of a chev rod.
btw these are available from VPW for around $870.
Piston is a flat top design with a 2cc relief
Pistons arrive from U.S after an eight week wait.Quality looks good .All pistons weigh exactly 490 gms with pin. Valve relief a little sharp and needs deburring.
Any idea if this piston would work with a modified 4" stroke 400M crank and 6.02" 302C cleveland rod (little end opened out from 0.912" to 0.927"). Numerically it is only 7 thou out of the hole which is OK, but how about crank counterweight interference down below?
methanol injected clevo
My 393c
3.85 SCAT crank
6.00" Chev Rod
SRP short skirt forgie, i'll try to get more info
We're doing a dummy fit this weekend to check out clearancing, using a 9.2" factory block
Theoretically its close to your intended application but what you have to consider is that you have more stroke and a shorter rod than what i have and that means you may run into clearance problems with the crank counterweights hitting the piston skirt. No easy way of telling unless you are prepared to pop for a set.
xr8_sprint said:
My 393c
3.85 SCAT crank
6.00" Chev Rod
Interested to find out if the 6 inch rod combo cleared the crank counterweights?.
Hey tmg70gt, Just wonder if you have a part number on the pistons you are running, thinking they must have a 1.00" pin height, im looking for something close to this piston thanks
74 XB Fairmont
ClevelandRocks said:
Just curious, do the pins end up in the oil rings of the piston with the 4" stroke and 4.2" rod?
You mean 6.2" rod. Yes they do. Hence why most kits for clevo blocks only use a 6" rod when using a 4" stroke.
66 Mustang 351C
also must be why you guys seem to favor the 393 over anything much bigger.... 4.2" rod??? Well that wouldn't foul the oil rings at all would it! lol
74 XB Fairmont
No cleveland combination uses 4.2" rods.
Cleveland combinations use:
5.788", 6" and 6.125".
The 408 combo's that use the 6.2" rod is not using a cleveland block. Generally a Dart or SVO block. The 6.2" rod requires you run a 9.5" deck height. Cleveland is 9.2" deck height.
You can't go any bigger than 408 in a factory cleveland block. Otherwise you'll smash your pistons into your cyl heads.
I'm not 100% sure but I think you have "stroke" mixed up with "rod length".
351 = 3.5" stroke
378/383 = 3.750" stroke
393 = 3.850" stroke
408 = 4" stroke.
Any larger than that and the crank counter weights smash into your oil pan rails.
66 Mustang 351C
thanks Brenx,
My second reference to a 4.2" rod was in jest.
I have seen stroker kits for std C blocks, with std 9.2" deck heights using 6.2" rods. The SCAT 408 inch kits show that option anyway. Must be pretty high pin pistons and I would guess a bit of block clearancing and a punched out tray would be needed too for sure.
Anyway, my question to TMG70GT was about the pin height in his 408, with 6.2 rods, in a std C block. I don't see any way with that combination to keep the pin out of the oil control rings on any piston. That's what I was trying to say anyway, I do see I botched that a bit. :)
I was curious if oil consumption was an issue.
Anyway, thanks for the correction. Have a good one.
Dave
66 Mustang 351C
thanks for the link assist. long one eh?
Good reading. All of it's been pretty helpful to me in my decision making process.
"Can't claim to know what I don't learn" Sometimes it comes the hard way :hy:
393 seems like the magic cube for the Clevo. I'm impressed with the research Mark did on his 408 kit(s). Just don't have the bucks to do it right and I did read the "if it's gonna be 408, it's gotta be done right" part. Not much sense building a grenade.
btw. the guy who did my machining last time builds circle track 358C's.
He recommended and got me a set of "full groove" main bearings and I don't recall the brand. I know they aren't Clevites.
Do you use em?
Dave
74 XB Fairmont
According to my reciept. My mains are stock type bearings.
I used an ACL race bearing on the rods. I'm not sure whether they were full groove or not. If I get bored later this year? I'm going to pull the engine out and check over it. Might do it in Nov/Dec?
Full groove bearings wouldn't hurt as clevelands are known for starving oil in the rear of the block.
1 - 20 of 40 Posts
