1 - 13 of 13 Posts
· Registered
I have a 302 in a kit car, the casting # on the block starts E0 so I think it's a 1980 block. I can't get it started. I have replaced the battery, starter, coil, wires, plugs, cap and rotor, alternator, control module, solenoid, and other electrical parts I can't think of at the moment. I also replaced the timing chain. Considering the car is a fiberglass body I have made sure that all of these components are properly grounded. It cranks, I have good spark, fresh fuel, and I can't even get it to backfire. I have adjusted timing more than once, checked firing order, still nothing. I'm running out of ideas. What am I missing?
· Super Moderator
Let’s start with the basics. Is it carb’d or efi? Have you verified it’s getting fuel into the chambers? Which firing order is the cam?
· Registered
Thanks for your interest. carb is edlebrock 4bl. cam is 351 windsor firing order 13726548. I know the fuel is getting to the carb , if it's not getting to the chambers I think I would have puddles of fuel backing up. How would I test for this without pulling the intake ?
· Registered
Discussion Starter · #5 ·
the plugs are new and smell like they are getting fuel. Ignition is het ford. Most recent timing was when I replaced the timing chain, #1 cylinder at tdc and distributor rotor pointing to #1 and then a few degrees advance and few retard. Couldn't get a pop
· Super Moderator
Did you have the valve cover off to ensure it’s tdc of the compression stroke? Not trying to belittle you but it’s best to check all your bases. And when you checked spark did you check at the coil, dizzy or plugs?
· Registered
Discussion Starter · #8 ·
Yes ,, valve covers off both valves closed. I even had a plug tool in #1 to stop piston at tdc. I grounded plug to block to check spark. thanks
· Super Moderator
Maybe the spark is weak. Kind of a stupid question but do you have compression? Have you tried slightly holding the gas down while cranking?
· Super Moderator
I dont think " I don't know if efi was available in 1908 " it was in that year :) Joking aside , try with a jump start and using easy start .You never know with cars , stranger things have happened .
· Administrator
With everything you have explained here if you have a good spark then I would be suspecting the ignition timing or firing order.
Check you dont have a large vacum leak somewhere too.
It must be close to getting fired up with all you have explained.
· Registered
Did you change camshaft ? If the lift was higher than stock and you did not allow for that it is possible valve lash is not correct and you do not have compression. Run a compression check and let us know the readings, are the heads still stock. Maybe this will be of help
1 - 13 of 13 Posts
