1 - 11 of 11 Posts
can anyone tell me when building a 347 stroker if there are any other options of pistons and rods that are cheaper than the recommended 5.4 rod length
you could get yourself a eagle stroker kit, they're pretty good in matters of bang for your buck, they're about 1200 bucks for a complete assembly but less then that is pretty doubtful i'm afraid
Also there is a scat rotating assembly on sale (ithink its still on sale) for 1365 aus or I have heard of being able to offsetgrind a 351 crank?/ or something I will have a look in my books for ya.
Classic not Plastic!
331? Haven't heard of that one before, whats that like? Sounds revvy
the 331 uses a 5.4 rod and 3.25 crank , this allows the piston to have the pin further down over the 347 kits, some of hte 347 strokers have oil burn problem due to the pin going thru the oil ring.
you can find stroker kits for around 700-1300 on E-bay. They are usually the eagle brand, but there are other. I am considering converting my 302 in my 78 cobra II to a 347 stroker as well. Just gotta get the funds
why not go all the way to 383???
not saying this as a poke in the ribs.....
Its the same block/bore...just interested in the qualified justifications.
Jas
Hi.
I made a 347 from a 289 last year, i put in an Eagle kit with the 5,4 rods 4334 crank and forged SRP pistons. with 351 w heads with big stainless valves, some porting, a set of tri y hedders, a mallory unilite distributor, Edelbrock single plain intake and an Edelbrock 650 carb with manual choke.
This works fine, sofar i have had about 1000 miles of pure pleasurecruising in the car, 1966 Galaxie 2 dr. HT, and there have been no problems. :driver: :priest: :hy:
The kit was easy to install, The guys at Eagle was very nice and when i snapped a pistonring, they told me "no problem we will ship a couple of rings pronto" so as you can tell i am very pleased with Eagle, the product and the service.
So as soon as i find a 1964-1968 mustang convertibleproject, i´ll build another strokerengine, this time a 427 BOSS setup on a 351w block.. :hy:
Turbo 351TC "Coming soon"
You use a 302c crank. But the costs are up there. The Scat/Eagle kit form I'd say would be the best bang for ya buck.
Jas
How??? The Windsors have a different block for the 302's then the 351's there not like the clevelands.
1 - 11 of 11 Posts
