1 - 12 of 12 Posts
I'm looking for a 351-toploader-9"(disks) driveline to put in an XF ute.
A) Which models (xa/xb/xc/xd/eseries and/or fairlanes) had this driveline and
b) is the length of these diffs ok to fit under the ute or are mods needed?
Also, im after a lsd - but what ratio? It'll be mainly fwy driving, so id like it to be sitting on ~1700 rpm at 100km/hr (it'll have enough torque :) )
Thanks heaps in advance,
Mik
Yea, good luck finding a 2.05 ratio diff. To achieve such low cruising revs, you will need an overdrive box, and the cost and frequency of replacement clutches will far outweigh any perceived fuel economy benefits without one.
Whats traction?
Either that or get the biggest diameter rear tyers you can find.
32" and 2.75:1 should do it....
Mine revs at 3000rpm at 100 and doesn't use as much fuel as you'd expect. Once your moving it doesn't take much fuel to keep it rolling.
Hehe thanx guys - sorry, the ~1700 shoulda been ~2700 hehe
So i take it a 2.75 will sit on 3k? (anyone know the final drive ratio of toploader??)
Also, am still keen to know which models come in 351-toploader-9"... anyone?
Mik
Munch Munch Rice 4 Lunch
if your aiming for 2700 rpm then you can use 3.23 gears with standard height tyres, 235/65.
if the motor will have a bit of grunt behind it then you can use 2.9 that should drop the rmp down to about 2500, but the overdrive would make alot of difference too
3.25 about 2700, 3.00 about 2500, 2.75 about 2290, all at 100km/h in fourth, which is 1:1 ratio.
There is little point putting in a nine inch if the engine isn't a bit of a weapon.
If the engine is a weapon, you cant gear it for 2,700 @ 100km/h as it will kill it. If it's a mild engine used just for cruising, stick with what you have.
It's probably not what you wanted to hear, but that's how it is.
Discussion Starter #9
Thanx guys - i'm going to build a decent gas engine (380-400hp) for it concentrating on max mid-range (3k-5.5k) torque (i wanted a 460, but thats a bit of overkill just to tow stuff around :) and considering u get a 9" in the donor, why not? At what hp should one think of going 9"?
The 3.25 or 3.00 sound like the most suitable - but which ratio is easiest to get as an LSD out of a wreck (ie whats most common)?
Mik
PS> Why would having a high overdrive kill a decent engine? If u get to a hill, then change down and get the revs to where it can pull... I find v8s love to just sit and tick along at (relatively) low rpm until they are needed. my 2c worth.
Can't wait for Winton...
I would have thought a ZG-H Fairlane, or XB-C would be your best bet here for a 351 toploader and disk brake 9" (plus they're often rusty so you can find cheap "donors"). The earlier Falcs back to XW had drum brakes. Ok, not too many Fairlanes would have the 4sp, but it'd probably be harder/cost more to turn up a disk braked 9".
I don't think the leaf spring suspension changed on Falcons so a 9" out of any leaf-sprung Falc should be ok.
As for the ratio, first find the bits. Chances are it will need rebuilding anyway unless you know its history, so it's easy to change ratio then if necessary but you're most likely to find a 3.0 or around that.
Racer - not having a go, but what's wrong with having a sensible ratio diff for highway driving behind a strong 351? He's obviously not after the best possible 1/4 time. A 9" will take more punishment that the BW diff, so apart from the weight difference and a bit more cost, why not?
Discussion Starter #11 (Edited)
Great - thanx for that! Im also assuming that the diff width would be ok... :)
Did the XE come in a 351 fairlane version? and did they use the xe chassis? (im thinkin the donor would make a great interior/mod cons donor too :) the cruisecontrol, pwr windows etc would all fit straight in... yay!
Looks like ill have to source a toploader seperately...
Mik
PS> drove a '03 ss ute to newie 2day to pick up my ute - not a bad car, but the 6-speed is brilliant! 1600rpm at 100km/hr, seriously. and it pulled it up Mt White without even a murmor... so i guess a tall diff aint all that bad, because she'll still step out in 1st and 2nd :) Pity Ford dont make a 6sp for a 400hp 351... :(
.... Pity Ford dont make a 6sp for a 400hp 351... :(
Tremec do,lol. Bolts straight in, put one in a previously FMX 351 XC coupe a few months ago.
1 - 12 of 12 Posts
