1970 cougar 351W. Has anyone ever heard of or found the eccentric 2 piece with a broken tab. Causing fuel pump driver to center on gear, not allowing fuel pump to operate. With everything I have done to Fuel system, this what I believe is causing no fuel, no start issue.
Administrator
I guess anything is possible.
Have you checked there is fuel getting to the pump.
If so then if the pump is not pumping any fuel then at least you can work in that area.
Remove the pump and operate it manually to check.
If all this checks out and if you have replaced the pump and are sure its the correct part for the engine then it could well be the cam drive area to look at next.
