Thanks very much Kionga. I really appreciate your detailed response.
I wonder what the C/R would be with stock flat-tops and 2VCC heads.
What would you consider to be a "desirable C/R" ?
What is the make and grind of the hydraulic that you are not happy with ?
The profile appears to be very docile for a 408 cuber.
Any idea what the lobe centreline angles are on both cams ?
Why the change to a solid grind ?
Do you think a manual steering box would give more room then the power steering one?
Would the 4 into 1 extractors be easier to fit then the Tri-Y's ?
I'd consider ditching the clutch fan for EF/EL twin thermos. You'll need a bigger alternator and a decent battery, but boy do they work well. They also dont take up as much room as the clutched unit, plus mine automatically turn off when I'm cruising, thus reducing alternator drag and increasing economy. I'll never have another belt driven fan again.
Thanks again.
Thanks again.
