Greetings all, I've posted this on www.fordforums.com, but I thought I'd post here as well, any extra help counts
Ok, I've been working on my ED for a while now, got her up to 190rwkw with the following mods -
Crow EA-ED Wild Performance Cam (222825)
EA-EF Vernier adjustable timing set (CS6EA-VS)
Falcon XR6 valve springs (7739-6)
2 1/2 inch Pacemaker extractors, 2 1/2 inch high flow redback cat & mufflers (PH4499, STR110, 2T3870TP)
now, supplied and fitted by Herrod Automotive -
Oil pressure switch,
Water Pump,
Distributor MPEFI (F005D00002)
Coil (9220061710)
new sump gasket set,
6 Cyl head Gasket kit (EA6584BK1T)
New timing case,
New oil pump,
NGK plugs (BRE527Y-11)
Pistons/Pins
Crankshaft bearings,
Lifters,
Con rod bearings,
ported & polished Cyl Head,
VRS gasket set,
Unichip computer,
Fuel pump,
new 91LE auto & torque convertor.
Now, I'm looking at further work, before eventually looking at a turbo.
Basically, I've got a list of things I'm planning on, and I was hoping that all of our good freinds on the board would be able to help out with approximate prices.
LSD Diff -
3:73 Gears -
Titanium Valve Springs -
AU Steel Head Gasket -
Trans Cooler -
Pistons/Rods/Rings/Bearings - ACL Race Series - Sizes 0.5, 1.0 ??? (Not totally certain of the meaning with the different sizes)
Size 0.5 - Rods 6B2150H-010, Bearings 7M2158H-010, Pistons 6MKRY9400 (includes Rings), Gaskets GR520/1GTR, GR522GTR.
Size 1.0 - Rods 6B2150H-010, Bearings 7M2158H-010, Pistons 6MKRY9400 (includes Rings), Gaskets GR520/1GTR, GR522GTR.
Fuel Injectors - (Not certain what would be right, and what'd be overkill)
Fuel Pump - (As above)
Braided Steel Hoses -
Guages -
Oil Temp - $
Water Temp - $
Trans Temp - $
Air/Fuel Ratio -$
EL XR Guages - $
Also, if anyone thinks of something I've missed along the way, please let me know.
Any help VERY much appreciated. And if anyone knows the best value places to source the items, that info would be great also! :hy:
Water Pump,
Coil (9220061710)
New timing case,
New oil pump,
Pistons/Pins
Lifters,
Con rod bearings,
VRS gasket set,
Unichip computer,
Fuel pump,
LSD Diff -
3:73 Gears -
Trans Cooler -
Guages -
Oil Temp - $
Water Temp - $
Trans Temp - $
Air/Fuel Ratio -$
EL XR Guages - $
