hello i currently own a 1962 ford falcon 2dr wagon this is what i would like to do to it. lower the front end lower the rear end convert to a 5 lug bolt pattern front and rear install 17'' wheels and tires. i would like to know if their is a 5 lug rear axel that would fit in my stock rear end also is their a 5 lug front hub and drum that i could use with my stock spindle also info needed on lowering the car . any help would be grateful thank you
Probably best to post your question in the US section, dude.:hy:
ST170ish
You need to look for a donor car with the same track measurements on the rear, or you will need to get a cut down one(leave it to the pro's... Castlemaine rodshop...XK-XL-XP-XM Ford owners are also catered for for with the U.S.A. V8 Sprint diffs. A full range of rear universals, U bolts and tailshaft weld yokes are carried in stock. We will also build your custom tailshaft for any application and will custom build slip yokes if required. Turbo 400 auto, 31 splined FMX auto and Toploader manual slip yokes are carried in stock.)
http://www.rodshop.com.au/intro.htm
This should help you
