1 - 20 of 22 Posts
· Registered
hello all, hope someone can help me!
i am trying to identify what my motor came out of so i can order the right parts.everone i talk to at the auto parts stores say that they can't identify or get the right parts because it could be a "special" or a "thunderjet".
here's what i know so far
C9VE-B on the block and C9VE-A on the heads. it also has 9A16 stamped on it.
intake has C8SE-9425-B stamped on it
i really want to rebuild this motor, it will be turning the 44" swampers on my 81 Bronco!
thanks :beerbottl
· 429/460 Fanatic
thanks :beerbottl
You have a very early 1969 base model engine. If it is a 429, then it is as much a Thunder Jet (not Cobra Jet) as any other 4-barrel 429, and is factory rated at 360HP. Might be a 460, too, but the only way to tell the difference is by unbuttoning the pan...unless the tag is still on the intake manifold.
1969 429 and 460 longblocks are made of 100% identical interchangable componenetry except for the crankshaft and pistons (which are exclusive to each of the engines). Even the bore is the same on both engines.
Paul
· Continental Mk IV
C9VE-B should be a 1970 429CJ engine block, C9VE-A should be a 1970-71 429CJ, SCJ and Police cylinderhead. Sounds like a nice engine!
I have this info from Tom Monroe's "How to rebuild Ford V8 engines" published by HPBooks, ISBN 0-89586-036-8. It's pretty old so I don't know if it's still published.
· 429/460 Fanatic
The alpha-numerical data in the book you are quoting is very incorrect and very inaccurate.
  • Contrary to your post, the casting number for a CJ & SCJ block is D0VE-A, not C9VE-B.
  • Contrary to your post, the casting number for a CJ & SCJ head is D0OE-R, not C9VE-A.
  • Contrary to your post, the most common casting number for a PI Head is D2OE-AB, not C9VE-B.
Paul
· Registered
coop 75 said:
Hi I have only just joined
I have just put a 429 in an XB coupe finding parts and getting answers was very
hard,but the best I found for parts and info was SOWKOS performance centre
in Adelaide .
G'day, just caught your thread. I'm currently in the throws of installing a 460 into my XB coupe. Any pitfalls other than springs and shock towers that you are aware of? I heard a rumour last night that there are some rear end twist issues, but its the first I've heard of it.
Luv the coupes.
Lee.
· Administrator
1 - 20 of 22 Posts
