1 - 8 of 8 Posts
429 Super Cobra Jet.
Engine is currently in an XE ESP and had a full rebuid about 8000klms ago.
A brief run down on the engine as too many things to list.
Engine is the 429SCJ
Heads Doves with big intake ports Heads Flowed and ported and polished.
Roller Rockers /Chrome Moly Push rods
Big Valves S/S
Duel Plane Manifold flowed
Mandrel Bent Headers to suit XD-XE-XF both Manual or Auto.
Solid Camshaft 3500 to 7500RPM range 595 lift
Bottom end:
Bored 30thou
Full floating Pistons
Mildon Rods and Bolts.
Engine is complete as Long Motor also will comes with engine mounts etc.
Will sell engine seperate or with:
C6 Auto with Shift Kit.
C6 was just serviced at All Trans on the Gold Coast by Greg Whittaker who originally built the C6.
C6 has the Bigger sump for extral oil and cooling.
3500RPM Hi-Stall convertor {Full Race version} No ballooning with this Stally as it has all the Anti Ballooning Plates Triple roller bearings etc fitted.
I am open to offers but must be serious Please.
Mercury Cougar Cool
Where are you located? Any carb included?
I just want to try something different.
I would be interested in a 378 Stroker as part trade, must be in very good condition + cash difference.
It has a holley 830DP but not sure if I want to let that go as it has had a lot of work done to it.
Never had it on a Dyno.
Looking for around $8000.00 ONO with Headers, but no C6 or 3500RPM Stall convertor.
I have a 2800RPM Stally that I will give with it
Will be up the Gold Coast in approx 2 weeks if interested, but would need a deposit and time to remove from car.
Let me know.
I can Trailer the engine up no problems.
Let me know if interested in the Holley as well.
It will come with Mandrel Bent Headers and 2800RPM High Stall convertor and Flex Plate.
If you are also interested in the C-6 Auto casing let me know but would need a C-6 casing to fit a Clevo in place of it, as I would swap all internals into the C-6 to suit the Clevo.
I can have that done at All Trans on the Gold Coast.
1 - 8 of 8 Posts
