1 - 14 of 14 Posts
Gonna fit a twin cam
Do you mean the eb-ed, or the ef/el. To answer your question, both will work. If you use the ef/el one, make sure you put plenty of silicoln at the front and rear to stop oil leaks.
You want to watch the throttle cable positions, unless that's the reason you're changing it?
wants a manual!
ive got a 4lt rocker cover you can have if you live in melborne. it has been paint stripped becaues i was going to attempt to polish it but now i can't be bothered.
351 windsor for the xr
will an AU rocker cover fit an eb xr6 i'm gonna change the inlet manifold to the ef one i'm wondering if a AU cover will work on my head i like the AU ones cause there similar style to the eb ones.
Yes, I have an AU cover on the 3.9 until I can afford to fix the AU motor :p
wants a manual!
TIKFD6 said:
I have been thinking of an AU cover myself, they look similar to the EA/D cover, and suit the BBM that i want.
:p
well if you ever change it i will buy your Tickford one you currently have.
there not cheap tikfd6 i've been ringing around the wreckers here in melb and not alot of em even know what a au xr6hp one looks like without the vct i saw one in an xls ute at a panel shop it had a xr6 motor in it without the vct if i can't find one for my bbm conversion i might buy one brand new from ford.
wants a manual!
werent the AU Tickford covers just a standard AU one painted red??
we get AU tickford motors in at work and all they do is paintstrip them and repaint them a dodgy bright red colour. bit of a waste really.
I went the opposite way EA cover on EF head, problem is fitting the gasket on as the EF head is thicker around the cam plugs.
nah man the one i saw had the tickford logo on it. it would look awesome in my engine bay i reckon
wants a manual!
that would be off an EB/ED XR then. the last of the ED had the half moons at the front. you might have seen that one. unless your talking about the AU VCT one. they had a tickford badge but it was on top of the head not the rocker cover.
1 - 14 of 14 Posts
