Putting in 351/400 mod will be looking for c6 transmission. What to do about drive shaft.can I use the one it has which is stock from the 292 y block 3 speed clutch or do I take the drive shaft with c6 from junk yard.
May need to get one custom cut if you're changing from a stock configuration.
I am thinking of finding one from junk yard a c6 with the drive shaft.then just take down to drive line here in town have it cut and hope the can give me a u joint for my axel.you know if the 351 mod is a external balance motor.i did not get a flex plate with motor so hope the flex plate from the c6 I get fits and is ok .
