hi I need some advice I am wanting to pick up a built 351m creating some good hp with a automatic with shift kit and headers currently in a 84 bronco but want to swap to my 67 mustang 3 speed 6cyl already 9" rear end and disc brake 5 lug front. any info on the subject would be greatly appreciated.
Anything's possible, but you may have to do some modifications. The 351M is part of the 335 engine series which was not offered on the 67-68 model years, but WAS on the 69-70. With minor modifications, you may be able to use the mounts from the 69-70 model years for the 351 Cleveland. Transmission mounts will vary with the transmission, the similarities between a Windsor block and a Cleveland block may be close enough to utilize the mounts designed for the transmission... providing you're going to use a transmission that was stock to the 67. Headers? Well... good luck. Might be best to go with shorties and use a custom exhaust to reach it. Linkage, once again, transmission dependent.
