My '87 B-II hs 2.9 with auto trans/OD. When hot and usually after driving 60+ Mph the trans leaks *bad*! Like a faucet, it pours out from the bell housing. It took 5 quarts just o get it home 2 blocks. Any help? How much to overhaul a 4ald trans? Really want to keep it, but also has a prob where it gets hot under strss, when using A/C. Thans in advance for any help!
Discussion Starter · #2 ·
believe it or not this happens alot.. I just put an 88' A4LD in mine to replace my 85' A4LD That only had 60,000 miles on it... I'm in the process of swapping to a mitsu 5-speed.. if you keep your A4LD Tranny you will always run into this one way or another.. but if you are really interested in saving your tranny.. check this out at the rangerstation.com
http://board.rrorc.com/ubbcgi/ultimatebb.cgi?ubb=get_topic&f=22&t=000777
don't leave any spaces.. there are links to who,what,when,and where.. as to why i have no clue.. I'm tired of taking mine out and putting a new one in..
