J
my name is jeff. i restored a 67 mustang with a 289/30 over. i want put a
87 5.0 electronic distributor in place of the old points distributor. how
do i accomplish this?
i would
appreicate the intel thanks jeff
B
Discussion Starter #2
> put a 87 5.0 electronic distributor in place of the old points
> distributor. how do i accomplish this?
You dont, because then you would lose spark advance - you use a Duraspark
II dist.. Used in mid 70's to mid eighties small blocks.
You CAN use the TFI coil, however...
here's a good source of info.
http://users3.ev1.net/~bmarr/duraspark_ignition_upgrade.htm
Yeh, I'm a Krusty old Geezer, putting up with my 'smartass' is the price
you pay..DEAL with it!
J
http://www.pertronix.com/
This will keep the stock look to your engine, if that's something you're
after.
If I was buying a whole ignition system, I don't think I'd fart around with
used parts or even NOS stuff. MSD, Mallory and others can supply you with
what you need to make a pretty painless installation...
"jeffgrever" <[email protected]> wrote in message
news:[email protected]
> i would
S
On Mon, 13 Feb 2006 22:41:32 -0500, "jeffgrever"
> i would
I went with the Pertronix Ignitor II, which goes inside the stock
housing and keeps the original look. VERY easy install - 15 minutes
and done. Just a slight wire change. And you can either remove the old
wire or leave it in place to keep the original look.
Like the brands mentions, I find it is doing a good job. Some may be
better tan Pertronix, but I'm happy with it. I added the Pertronix
Flamethrower coil, and an 8 mm wire set to match.
Pertronix and the others do make a complete distributor you can drop
in... for a lot more bucks : 0 ) than an upgrade kit.
Spike
1965 Ford Mustang Fastback 2+2, Vintage Burgundy
w/Black Std Interior, A Code 289 C4 Trac-Lok;
Vintage 40 16" rims w/225/50ZR16 KDWS BF Goodrich
gForce Radial T/As, Cobra drop; surround sound
audio-video...
See my ride at....
Feb 2004- http://207.36.208.198/albums/86810/003_May_21_3004.jpg
Feb 2004- http://207.36.208.198/albums/86810/005_May_21_2004.jpg
Jul 2005- http://207.36.208.198/albums/86810/davescar_7_11_05_002.jpg
Jul 2005- http://207.36.208.198/albums/86810/Engine_rebuild_006.jpg
M
What's the reason for installing an '87 distributer? If you're going with
fuel injection the I'd say yes but if you keep the non-roller cam you'd need
to install a cast iron distributer gear on it otherwise your cam will lunch.
Mark
"I'm not as dumb as I lead you to believe" :)~
