Hello all from a long time Probe owner and first timer here.
Although my first love is Corvettes, my daily driver is the GT!
I have had this car for six years and have been experiencing a major problem since I let someone else drive my Probe. It came back with coolant in the number 1 cylinder. I removed the head expecting a leaking head gasket, what I found was something much worse. It has either a small crack or pin hole in the sparkplug hole. I bushed the hole with a Helicoil insert (it looks something like a pipe bushing) and JB Weld smeared between the threads of the insert and the head to seal the coolant leak. It worked for three months. The cost of a new head is way out of line, a wrecking yard head is somewhat similar.
I have purchased a 91 non turbo car for parts ( hey it was only $61.00 per Ebay). My local Mazda guy tells me that the head is the same for both, I'm assuming if so, that the cam profile, springs and valves are not.
Can any of you Probe experts confirm this?
Thanks for any information you can supply.
Mike
Mike
