Need help '89 sable head lights rely dim, i put in new bulbs but is still dim cleaned outside of lense but dont no how 2 clean inside need help...
If The Bulbs Are Dim Your Most Likely Problem Would Be A Bad Ground Connection. Your Going To Need A Wiring Diagram To Locate The Ground Connection/s. Good Luck!!!!!!
You could be not getting enough draw from the electrical system to the lights. have you noticed any other issue other than the light issues?
