Hi all. Got a 91 3.0 lx probe. Got injector pulse and spark but no fuel pressure. New pump,inertia switch and still just can’t get pressure on pump to turn on. Any help would be greatly appreciated
Did you replace the pump or entire module? On my 95 Probe I applied 12v to the pump side of the inertia switch, and disconnected the pressure fuel line at the pump. I connected a long piece of fuel line to the pump outlet and saw plenty of fuel. My distributor was bad.
Thanks for the reply. I actually got it figured out I lost power at the sending unit. If I jumped pump it worked but wouldn’t work under normal operation. So eventually found the ground on the module to be my problem. Thanks again.
Glad you found the problem. It's a wonder we keep these old cars running, parts are getting scarce.
Yah I hear that. I have 3 now and some random parts if I can ever help let me know. I’ve just been into these things for past 20 years
