Hi everyone, just found this forum, but it looks pretty good. I have a 93' T-bird and a few weeks ago the headlights started flashing. They just flash on and off as you drive down the road. Both hi beam and low beams flash. I messed with the pull switch that turns the lights on and found nothing there. The only thing that I found will work is when you pull the hi/lo swith all the way back and then the hi beams will stay on and the lo beam will flash. At least people can see you and you are not flashing at them. I am guessing it is the hi/lo switch, but just thought I would check and see if anyone has see or heard of this.
Thanks for any info...
Mark
