My 94 Mustang is over heating, I took it to a shop, they changed the thermostat, this did not help. Took it back they checked the fan,its electric, then they changed the sending unit. Still no change it continues to over heat. Please help, I lost
Mod/Multicar Member
its possible that you have some air trapped in the system. your mechanic should have blead the system when he did the thermostat. you might want to have someone els check it for you.
Air dam
Try this, make sure that the plastic air dam under the front end is still there. Chances are it got busted off on a parking block or curb. You think I'm crazy but without it the airflow is smooth under the car and the the vacuum that is normally there with the air dam is gone (or decreased). The vacuum helps draw air over the radiator when the car is in motion. Sounds crazy but it fixed my problem for about $12 dollars. Don't forget to buy the little plastic fasteners to hold it on.
Good luck!
