·My problem started a couple weeks ago. The ABS light came on, aprox
1/2 hour later my brakes were not working properly. The pedal felt
all wrong (goes all the way down with no pressure) and it sounded like
the breaks were intermittingly stopping (like skidding) when they did
work... very dangerous to drive this way.
I took the truck home and checked the fluid, it turns out the fluid is
low, so I replaced it, still no puddles in the driveway and from
checking the inside (quick look) and around the wheels no leaks.
I took it up to the garage where I bought the truck and the guys up
there (without looking at it) say it sounds like it need's a master
cylinder. What is your opinion? Is there anything else I should
check into before I buy a MC and try to install it myself? Any advise
about installing a Master Cylinder?
I bought this truck used and I really fell in love with it. I'd like
to do the repairs myself when possible, but I donot have a ton of
experience with this type of thing, so it is a learning process for
me. Any kind of insight will help!
Thank you
Kevin
Thank you
Kevin
