H
Hi again group.
Q. My '96 940 estate 2.3 lpt has a problem with da headlights.There a bit
dim and yellow.
I've seen that the reflector has worn out on the upper side ( too much heat
from the H4 bulbs in 10 years) so the reflection is'nt like it used to be.
Hope the solution is a replacement reflector (on both lamps),Seen there are
clips on the glass, hopeful.
Took my voltmeter and between the battery and the lamp is 1.1V across.Think
it's too much.
Any experiences?
Typical values ?
Bad relay contacts ?
Found grounding leads on both ends,the same corrosion no actual
resistance,think i have to follow the complete circuit trough.
Any answers, thx in advance, Hans.
1 Participant
Hans de Koster
