'95 crn vic, the a/c compressor will not always run. I jumped out the hi and low pressure controls (there was 12v to gnd at both), swapped the a/c cut out relay with the fuel pump relay. Jiggled the interior controls. Check all fuses.
When the car is first started the clutch may engage for a few cycles the it shus off for 1 minute, 5 minutes, 10 minutes there is no standard.
I've thought about the throttle position sensor only because of the WOT but dismissed this since the car otherwise operates fine.
The electric cooling fan is operating fine.
Computer problem?
Any Ideas?
Jim
Computer problem?
Any Ideas?
Jim
