My odometer recently stops functioning then starts up again. Is there an easy way to remove it from the dash?, I was going to try to use compressed air on the gears? Can I come up from under the dash and get to it? I am hoping that this will fix the issue.
Thanks in advance.. :priest: :priest:
Speed sensors are usually what causes this problem. If you are 4wd , there are two of them. Take them out and clean them. Very easy to do. :hy:
