I'm wondering if anyone knows the location of the fuel pump relay in a 95 Taurus SHO 3.2L...
I am having trouble with the car starting... When I try and start it, it cranks for a long time, and then it sputters and finally starts. Sometimes it will crank for a long time and not start at all. I'll have to stop cranking it for a couple seconds and try to start it again a second time. But it always fires right up the second time I try to start it. It started doing this after I changed the fuel filter a couple months ago. I thought either the check valve in the fuel filter was bad, or I had a bad connection which was letting air into the fuel line. Well yesterday I took off the cheap fuel filter I originally installed, and installed a Motorcraft fuel filter. Still the same problem. A buddy of mine said he thought it might have been the fuel pump relay going bad. The relay that purges the fuel pump when you turn the key on. I can't find where it's located. My Haynes book doesn't show me where it's at, and neither does my owners manual.
If someone knows where it's at, please let me know. Or if anyone else has any suggestions as to what my problem might be, also please let me know. Thanks to all in advance.
