The glass unplugs from the housing,you can measure continuity of the
heater section .
If it is open the glass part can be purchased with out buying the
entire mirror assbly
John
On Sat, 14 Jan 2006 17:33:00 -0500, Atif <foo@foo.com> wrote:
>The passanger side power mirror does not heat/defrost. Otherwise it
>works fine and I can change its position.
>The driver side works just fine.
>Any on what is wrong? If it were a fuse or wiring issue it wouldn't
>work work at all, right? I'm thinking it is the heating/resistance
>element.
>Any advice on fixing this would be appreciated. Since it otherwise
>works I'm not inclined to replace the whole mirror.
>-Atif
>'96 850 wagon 5sp
> element.
> -Atif
> '96 850 wagon 5sp
Remove the door panel to gain access to the mirror wiring and then check
the resistance across the mirror heater element. If that's open you'll
have to see if you can get the mirror apart for a better look, otherwise
you may need to swap the whole mirror.
Related Threads
1.4M posts
115.4K members
Since 1999
