J
My 96 850 T has 245000 miles. When cold it starts fine however if driven a
short distance 1/4 - 1/2 mile and shut off it sometimes wont start. When
the ignition is turned to start it only makes a faint clicking sound, the
starter doesn't spin. After 10 or 15 minutes it again starts fine. If
driven more than a few miles after a cold start everything works fine. My
initial feeling is that the starter brushes are worn and sticking. Any help
in diagnosing this odd problem will be appreciated.
Thanks
John
R
Discussion Starter #2
John
This could be a couple of problems but I would start by checking the
battery itself (does it hold a good charge?) and then the connections
from the battery to the starter (corrosion, loose wires etc) . Then
check the starter selenoid.
Regards
Russ
1 Reply
1 Participant
Russ
