Hello all,
I have a '97 Mustang with the 3.8L and after driving a GT i was wondering if it is possible, and if so how easy it would be to drop either a 302 or a 351 in it. Another question i have about the same car. I have a 5 speed in it, and was wondering if it is a T5 or a T45. And if that would make any differance in the upgrade? I'm looking for any help i can get to make this conversion as smooth as possible. If anyone out there has done this process and ran into any problems, or found any tricks, i would REALLY appreciate the help. Thank you in advance for any help you can contribute. You can either reply to this post, or e-mail me at [email protected]
There is a lot of hassle involved. Plumbing for everything must be replaced, along with wiring length change's, and all your bracket's must be changed or modified. The computer must also be modified or changed to accomadate the V/8.
The transmission is more than likely the "Mazda" design which would probably do the job as long as you don't abuse it. Ford didn't in stall the T5 behind the V/6.
V
97 engine swap
not to mention ford changed the k-member in 96 to fit the 3.8 and 4.6 engine( meaning your k/member will not accomodate a 302 or 351). and as big1 stated the wiring harness will have to be changed, as well as the computer. It will take a lot of effort, but it is possible:)
(change the t45 to the t5 or it wont work)
3 Participants
v8stang289
