No, just one switch and the light is not on. I just had an issue with it and replaced it. See here.
"From: "John" <
[email protected]>
Subject: 97 Taurus - cannot shift out from P
Date: Monday, January 16, 2006 5:19 PM
80K miles on 97 Taurus GL, seems like the lever is stuck in P and doesn't
move. We went to a nearby Meineke mechanic who shortened a wire around the
brake pedal and it solved the problem. However he told us to go to a Ford
dealer so they can fix it permanently.
Also, when we got back home we noticed that the brake lights won't turn off
(after this cable jumper).
Any idea? "
And this is the outcome:
BOO it was.
Aparently (my wife didn't see) the wire broke out from the connector and
when the Meinke guy took the switch he didn't bring the connector back, so I
didn't even know there was a connector, I only saw the BOO with two separate
wires connected to it.
This morning with better light I noticed a little pin that looks like it is
there to hold an electrical connector.
Went to the local Ford, they didn't have the BOO but they checked at another
dealer and they had one. Then the guy (at parts) sent me to the shop to
check if there is a recall on this thing. There was a recall, but on later
models. He also told me that there should be a connector. So I did buy the
connector from them and he told me to check the parts store accross the
street instead of going to a different town for the part, since most
electrical parts are not even manufactured by Ford any more, they are all
OEM (including the connector).
So sure enough, the guy accreoss the street had it for $12.99 ($23 from
Ford...), plus the connector ($9.40), plus some wire shoes for $2 = around
$23.
"JohanB" <
[email protected]> wrote in message news:
[email protected]
> Are there 1 or 2 switches on the brake pedal ??
> If 2( 1 brake lites and 1 cruise switch) you probably moved the cruise
> switch while installing brake switch
> If just 1 switch make sure the brake lites don't stay on all the time
> "John" <[email protected]> wrote in message
> news:[email protected]
>> Well, I did replace the Brake Switch three days ago, but did not see
>> anything to adjust on it.
>> Can you please elaborate on that?
>> Thanks.
>> "JohanB" <[email protected]> wrote in message
>> > Brake switch adjustment ??
>> > When I turn the MASTER (cruise control) on, the green light in the panel
>> > comes on, but when I try to set the speed, nothing happens.
>> > Any idea about that?
