It is more then obvious that Ford really fouled up on the taurus design. All I see are posts about the Taurus transmission. Well I am here to join the ranks and ask for some advise. We have a 97 Taurus LX (not SHO motor) with 109k miles
Here is the problem
Overdrive is gone - when it supposed to shift the OD light starts blinking
Must drive in 2nd until about 55 then put in drive and it might shift to 3rd but you must keep the RPMs around 3k - 4k for the it to slowly get going into gear. It seems not to be able to down shift when and if Im lucky enough to shift to 3rd.
2nd problem - The cigerette lighter doesnt work. I have checked every fuse I can find in the fuse box. Is there another fuse or something else to check? I have bought an after market cig lighter and attempted to hook up but I cant find a power source coming out of the fuse box. [argh]
Any help would be appreciated.
Thanks
Brian
Willard, MO. :driver:
-smile and you will make them wonder what you are up to.
Here is the problem
Thanks
Brian
I think the trick here is to determine if the transmission problem is due to the transmission controls (transmission is changed electronically) OR the transmission itself. I would connect a test light (low power LED) between pin 52 (3rd gear) of the EEC and ground and/or pin 55 (overdrive) and ground and see if the signal to the transmission was calling for this gear (take care not to short these pins to ground). (Note .. these pin numbers may not be correct for your transmission .. make sure the colors are pink/blk (55) and ppl/org (52)). If the LED suggests that there is no electronic signal present to change the gear .. you may have a bad speed sensor (VSS).
As for the ciggy lighter .. they are usually powered by circuit breaker #12 (not a fuse) which also powers the horn.
1 Reply
2 Participants
Gary1234
