Hello all, my name is Amanda, and I have a 97 Taurus. Recently, I got into a wreck, got the car fixed and everything, got it back from the dealership, and suddenly none of the windows will roll up or down. Also, my power steering seems stiff. Can anyone help with this problem?? :beerbottl
Hi-Tech *******
Window problem could be a motor. If slamming the door makes it work, then that is probably it. If not, it could be wiring in the harness that goes through the door.
Stiff steering? Does the power steering make any whining noise? Either it is a bad power steering pump/low fluid/etc or the ball joints on one side or the other are siezed. This would also cause "Memory steer" where the wheel does not return normally after a turn.
