I have a 98 CrownVic with the 4.6 DOC, V8 that is blowing hot air from the A/C vents at all times, regardless of position (IE floor, defrost, etc), as well as having a dead miss on the number 5 cylinder according to a scanner code 0535 I believe. HOWEVER, the a/c compressor is running the whole time, feel cold air coming out of the line access ports on the engine compartment air box, but blowing hot air from the vents. Though if I disconnect the battery, resetting the computer and temporarily delete the MIL trouble code from the ECU, the A/C works correctly, the engine is no longer sluggish and the MIL lamp stays off for a short period of time. It then comes back on, engines starts missing on number 5 again, and A/C blows hot. I have checked the coil to plug boot for cracks, splits, compromised areas, to no avail. The plug is firing blue and hot, and on time. The spark plug appears in good condition and gapped correctly. Cylinder compression is good, and all cylinder chambers are less than a 1 lbs difference between them all. Using a pulse lamp I also checked for injector pulse commands, all appears well. I have to admit at this point, after standing in the hot texas sun cookin my brains, I am at a loss.:wank2:
Any and all help would be greatly appreciated.
