Hey there. I've got a 98 5.0 V8 Explorer XLT with 68k on it. I've got a
problem with heat and AC where, regardless of the
setting(heat/ac/floor/front vents/defrost), all air ONLY comes out of
the defrost vents up front. The level does go up and down(both fan
strength and hot/cold) when adjusted... basically everything works
normal except it only comes out of the defrost vents... very
frustrating. Any tips would be GREATLY appreciated. I'd prefer to fix
it myself if possible(I'm hoping it's just a disconnected hose or
something?). Any help would be greatly appreciated.
Thanks all!!!
Matt
Discussion Starter · #2 ·
No vacuum , check for loose/broken vacuumhose under hood, passenger side
<[email protected]> wrote in message
news:[email protected]
> Thanks all!!!
> Matt
I agree, vacuum problem. When it comes out through the defrost, it is
in "default mode", which happens when the vacuum does not work. Look in
glove box, there is usually a manifold with vacuum lines.
Discussion Starter · #4 ·
Dead on.. I just recently had this problem and ended up tracking it down
to one of the solenoids that control vacuum to lock/unlock the front
axle. This would of course only be on a switchable 4x4 (not AWD). the
solenoid had a hairline crack and was bleeding vacuum slightly enough
not to hear it but enough to cause the problem.
HTH
Steve
