1 - 9 of 9 Posts
Could use ya'lls help before i call a locksmith.
I have a 1998 Mustang GT. Its a longer term project, and i let it sit for awhile, with and without the battery hooked up. I tried starting it up again recently and the engine would turn over but not fire up. While i crank it, the Theft light flashes.
All ignition components are new. The car ran ricky tick before i let it sit. Fuel Pressure test shows no fuel pressure. I am using the original keys, same keys that came with the vehicle and worked before.
Anything else i should check before i call a locksmith?
This is not for GT but might help ,
Ford Mustang (1994 – 1998) – fuse box diagram
Year of production: 1994, 1995, 1996, 1997, 1998
Passenger Compartment Fuse Box
Ford Mustang - fuse box diagram - passenger compartmentFord Mustang – fuse box diagram – passenger compartment
FuseAmpere Rating [A]Description
115Turn signal lamps
Back-up lamps
Airbag module
DRL module
Overdrive cancel
Brake shift solenoid
Heated backlite relay coil
Conv. top relay coil
Ilium, entry module (shut-off)
230Windshield wiper and washer systems
410Airbag module (aux. pwr.)
515Headlamp switch
Exterior lamps
Cluster ilium.
615Clock (ilium.)
Speed control amp.
Air conditioning clutch coil
RKE module (shut-off)
Anti-theft module (shut-off)
710ABS
810Chime for keys in ignition
Courtesy lamps
Engine compartment lamp
Glove compartment lamp
Power mirrors
Radio (MCM)
Instrument cluster (MCM)
Clock
Trunk lamp
Anti-theft (door open sig)
915Hazard warning
Stoplamps
Brake shift interlock sol.
1015IMRC (Cobra only)
20Heated oxygen sensors
1115Radio
1220Circuit Breaker:
Deck lid release
Door locks
1310Instrument panel
Illumination lamps
PRNDL ilium.
Ashtray ilium
1420Circuit Breaker: Power windows
1510Low oil module
Low coolant module
Safety belt chime
Cluster warning lamps
Cluster gauges
1620Flash-to-pass
Fog lamps
Anti-theft module
Low beams
Ext. lamps
1730Air conditioning and heater blower motor
1820Generator warning lights
EEC pwr. relay coil
Engine Compartment Fuse Box
Ford Mustang - fuse box diagram - engine compartmentFord Mustang – fuse box diagram – engine compartment
NumberAmpere Rating [A]Description
IGN SW40Turn signal lamps
Backup lamps
Air bag module
DRL module
Overdrive cancel
Heated backlight relay coil
Convertible top relay coil
Illuminated entry module (shut-off)
HEGO (4.6L only)
ABS
Low oil module
Low coolant module
Safety belt chime
Cluster gauges
Transmission shift module (4.6L only)
EEC power relay coil
Ignition coil
TFI module (4.6L only)
Starter relay
IGN SW40Windshield washer and wiper systems
Clock (illumination)
Speed control amp.
Radio
Power windows
IGN SW40Air conditioning and heater blower motor
HD LPS50Headlamps
Air bag module (aux. pwr.)
Chime for key in ignition
Courtesy lamps
Power mirrors
Radio (MCM)
Clock
Trunk lamp
Anti-theft (door open sig.)
Flash-to-pass
Low beams
Ext. lamps
Deck lid release
Door locks
EEC20EEC power
HTD BL40Rear window defrost
Fuel Pump20Electric fuel pump
Fan60Elec. drive fan
ABS60Anti-lock brakes
Power Seats25Power seats
DRL20Daytime running lights
Int. Lamps25Interior lamps
Audio25Radio amplifier
Subwoofer amplifier
ALT20Generator regulator
Cigar Lighter30Cigar lighter
Powerpoint
Convertible Top30Circuit Breaker: Convertible top
Thermactor30Thermactor (Cobra models)
WARNING: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market.
If the theft light is flashing the ecu is not recognizing the key, which does not let the fuel pump prime. Have you tried using both keys? Try cycling the ignition and leaving it in accessory for a minute and see if the theft light stops flashing. Also make sure the check engine light illuminates when you turn the key.
Administrator
Also count the theft light flashes if its flashing in pattern. For example, flash flash - pause - flash flash flash flash = 24
Sounds like a PATS (vehicle immobilizer) issue as mentioned above.
Locate your fuel pump reset switch (google) and push the reset button.
I think you have a bad fuel pump relay but they are so hard to locate on the vehicle. Ford placed them in different locations like engine compartment r/s, left side kick plate, behind the windshield washer reservoir and other places I can’t find. If you locate it post it here.
Most likely its a pats issue since the theft light is flashing.
Also the fuel pump relay is in the under hood fuse box. Later fox bodies had the fuel pump relay under the drivers seat.
Edit: Actually I was wrong it is in the ccrm in the passenger side fender.
1 - 9 of 9 Posts
