ok, might be in either the belt adjustment or the idler pulley, or even the
belt itself if it is frayed, although you were pretty certain there was no
noise with the engine running, and either of these should make noise then;
to check more closely you will need to remove the combined reservoir for the
windshield washer and engine coolant; there is only one bolt holding it in
and it you can see most of the serpentine drive belt with it out of the way.
Please let the group know what you find.
"paul1958" <
[email protected]> wrote in message
news:
[email protected]
> checked the fan blades not coming from there seems to be coming from one
> of
> the pulleys. might be the top one going to the ohc. not for sure though.
