...factory alarm for an AU2 to be specific
Has anybody got wiring specs, pinouts, wire colour codes or something like that for the factory alarm?
I'm trying to find out if the alarm has an 'armed output' (and which pin it is) - ie. a pin/wire which puts out a constant 12v when armed but 0v otherwise (or thereabouts). It doesn't have to be an 'official' armed output signal - just anything which behaves in the way I described, like a 12v out to a N.O. trigger - like the bonnet switch is (only prob is the bonnet switch wire is 12v even when the alarm is disarmed).
I tried to backprobe the pins on the control module, but I can only get to a few of 'em due to the bloddy tight position it's in and it doesn't seem real easy to pull out :fraz:
So if anybody knows, or even has an alarm lying around in the shed or something they could test for me or whatever, any info. would be much apriciated.
Thanks.
Thanks.
