1 - 9 of 9 Posts
Taurus Member
I need to replace a worn shock. I was thinking of replacing them with edelbrock shocks. What do you guys recommend? Does it make a difference in putting in a higher performance shock in classic cars?
Vintage Mustang Member
Shock selection depends on several factors. For example, when I put Michelin "X" radial tires on my ragtop and replaced the standard shocks with Monroes designed for radials. Bias-ply tires don't require anything but the standard rated shock. If you are looking to firm up the ride of the car, an adjustable shock might be considered. Air shock are also an option but I DON"T recommend them as a substitute for good springs.
Any of the standard national brands should give good service and if you are keeping your car basically stock, a common replacement shock would be satisfactory.
Classic Mustang Member
The air shocks remind me of one of those Mustang legends (such as urban legend) about keeping the shocks pumped up so it would miss a couple of grade "A" wide tires sticking out (or close to) below. Seems after some time "stress cracks" formed around the top post, or stud, of the shock. Well you can guess the rest of the story. Thump, thump, zing!
Anyway, to hit the hiways and byways I go with KYB GR-2 for that smooth ride. If you needed something that will control the cornering a little better then go KYB "Gas-A-Just".
(Q) Will a "high performance" shock it make a difference?
(A) Some, if you remove an used moderately good shock to be replaced. A big difference if your car has been riding around for some time on one or more worn shock(s).
cougar/bulletbird member
i run KYB's on all of my cars. i got in the habit and haven't ever had any trouble and i like to set my cars up to go out and play. hawkrod
Mod/Vintage Mustang Member
Another vote for KYB's. Not only do they provide an excellent ride, you don't have to shell out a fortune for them. Maybe a little more than the Monroes, which are also good. I think I paid about $30 a shock when I bought my last pair earlier this year.
Taurus Member
I plan to lower my car about 1" all around and I don't want to bounce like those imports. Will the gas-a-just do? By the way how much are they?
They shouldn't bounce. They give a nice ride. Like I said, you should be able to pick them up for about $30 each.
Taurus Member
Discussion Starter #9
I guess I will go with KYBs. Thanks for your opinions.
1 - 9 of 9 Posts
