1 - 11 of 11 Posts
Someone help me my ac stop working just one day to the other I check all the fuses, relay, ac control but still not working I just see the ac relay it’s not getting power if I jump power to the compressor it work I don’t know what more I can do thanks for the help
If you jump the relay and the compressor runs on does it get cold? Sounds like low refrigerant or a bad low pressure switch.
  • Like
Reactions: Bajarider
Yes I does It work good like normally just I don’t getting power to come on even to the ac panel contro.I know it can sounds stupid but the day before I change the cluster do you think it can affect I know the ac it’s independent But that’s when my ac stop working
I doubt it but I wouldn’t rule it out. Do you get 12v at the low pressure switch?
Here is the fuse box diagram for your vehicle . I would check every single fuse in the different locations that covers anything to do with air con , instrument cluster in case there are tied in to those circuits in any way . Fuse # especially
13152000-2004: A/C clutch
and
204A/C clutch relay
Ford F-150 (1997 – 2004) – fuse box diagram
Year of production: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004
Passenger Compartment Fuse Panel
Ford F-150 - fuse box diagram - passenger compartment fuse panelFord F-150 – fuse box diagram – passenger compartment fuse panel
NumberAmpere rating [A]Description
115Audio
25Powertrain Control Module (PCM), Cluster
320Cigar lighter, Data link connector
452000-2004: Power mirror switch, Mirror turn signal relays
151997-1999: Autolamp Module, Remote Entry Module, Mirrors
515Speed control module, Reverse lamp, Climate mode switch, Daytime Running Lamps (DRL) relay, Digital Transmission Range (DTR) sensor (2001-2004), AC Clutch Relay (1997-1999)
65Cluster, Brake shift interlock solenoid, GEM, Rear Air Suspension Module (1997-1999)
7
85Radio, Remote entry module, GEM, In-vehicle entertainment system (SuperCrew only)
9
10
1130Front washer pump relay, Wiper run/park relay, Wiper HI/LO relay, Windshield wiper motor
12
1320Stop lamp switch (Lamps), Turn/Hazard flasher, Speed Control Module (1997-2000)
1415Battery saver relay, Interior lamp relay, Accessory Delay Relay (Power Windows) (1997-2000)
155Stop lamp switch (speed control, brake shift interlock, ABS (1997-2000), PCM Module Inputs (1997-2000)), GEM, Rear Anti-lock Brake System (RABS) module
1620Headlamps (hi beams), Cluster (hi beam indicator)
17
185Instrument illumination (dimmer switch power)
19
205Audio, GEM, Powertrain Control Module (PCM), Transmission range sensor
2115Clutch switch, Starter relay, I/P fuse 20, Digital Transmission Range (DTR) Sensor (2001-2004)
2210Air bag module, Passenger air bag deactivation module
2310Trailer tow battery Charge relay, Turn/Hazard flasher, 4×4 solenoids, 4×4 relays, Overhead console, 4-Wheel Anti-lock Brake System (4WABS) module, EC mirror, Heated seats
24102001-2004: Function selector switch assembly
1997-1999: Climate Mode Switch (Blower Relay)
25102003-2004: Heated mirrors
51997-1999: 4 Wheel Anti-Lock Brake System (4WABS) Module
2610Right-hand low beam headlamp
275Foglamp relay and foglamp indicator, Main light switch (upstream) (2001-2004)
2810Left-hand low beam headlamp
295Autolamp module, Transmission overdrive control switch, Central security module (2001-2004), Beltminder (2001-2004)
3030Passive Anti-theft transceiver, Cluster, Ignition coils, PCM relay, Coil on plugs (2001-2004), Radio noise capacitor (2001-2004), ECC diode (2001-2004)
31
Relay
R1Interior lamp relay
R2Battery saver relay
R3
R4One-touch down window relay
R5Accessory delay relay
Power Distribution Box
Ford F-150 - fuse box diagram - power distribution boxFord F-150 – fuse box diagram – power distribution box
120Power point
230Powertrain Control Module (PCM)
330Main light switch, Headlamp relay, Multifunction switch
420Console power point (Harley Davidson only)
151997-1999: Air Suspension
520Trailer tow back-up/park lamps
615Main light switch, Park lamp relay
720Horn
815Power door locks, Central Security Module (CSM) (2001-2004), Lock relays (not used on SuperCrew) (2001-2004)
915Daytime Running Lamps (DRL), Fog lamps
1020Fuel pump
1120Alternator field
12202000-2004: Rear auxiliary power point
14
15102001-2004: Running board lamps
16152003-2004: Bi-fuel injector module, fuel selector switch and alternative fuel injectors (Bi-fuel vehicles only)
17
1818PCM, Fuel injectors, Fuel pump relay, Mass air flow sensor
1910Trailer/Camper adapter (right stop/tum lamp)
2010Trailer/Camper adapter (left stop/turn lamp)
21
22
2315HEGO sensor, Automatic transmission (2000-2004), Canister Vent (1997-2000), Powertrain Control Module (1997-1999), CMS Sensor (2000)
24151997-1999: Powertrain Control Module, Automatic Transmission, CMS Sensor
10130Trailer tow battery charge
10250Four-wheel Anti-lock Brake System (4WABS) module
20Rear-wheel Anti-lock Brake System (RABS) module, Ignition switch
10350Central junction box
104304×4 shift motor & clutch
10540Climate control front blower
106202000-2004: Intercooler pump (supercharged engine only)
107
10830Trailer tow electric brake
109501997-1999: Air Suspension Compressor
110302001-2004: Accessory delay relay (Not used on SuperCrew)
1997-2000: Power Windows
11140Ignition switch battery feed (start and run circuits)
11230Drivers power seat, Adjustable pedal switch (2000-2004)
11340Ignition switch battery feed (run and accessory circuits)
114
115202000-2004: Power door locks (SuperCrew only)
116402003-2004: Heated backlight
117
118302001-2004: Heated seats
Circuit Breaker
6012000-2004: Power windows, Moonroof (SuperCrew only)
602
Relay
201Trailer tow park lamp relay
202Front wiper run/park relay
203railer tow backup lamp relay
204A/C clutch relay
205Horn relay
206Fog lamp relay
207Front washer pump relay
2082000-2004: Intercooler pump relay (supercharged engine only)
209Front wiper HI/LO relay
301Fuel pump relay
302Trailer tow battery charge relay
3032003-2004: Heated backlight relay (SuperCrew only)
1997-1999: Rear Air Suspension Relay
304Powertrain Control Module Relay
3052000-2004: Fuel pump HI/LO relay (supercharged engine only)
3062000-2004: Inertia switch relay (supercharged engine only)
401
Diode
501Powertrain Control Module Diode
502A/C compressor diode
It looks like it changed in your year also ,
Ford F-Series F-150 F150 (2004 – 2014) – fuse box diagram (USA version)
Year of production: 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014
Fuse box in passenger comaprtment
Ford F-150 (2004-2014) - fuse box diagramFord F-Series XIII F-150 (2004-2014) – fuse box diagram
Fuse/relayAmpere rating [A]Fuse panel description
110*Run/accessory – wipers, instrument cluster, audio for XL/STX
220*Stop/turn lamps, brake on/off switch, hazard flasher
37,5*Power mirrors, memory seats and pedals, driver power seat
410*DVD battery power, power fold mirror
57,5*Keep alive memory for powertrain control module (PCM) and climate control module
615*Parklamos, BSM, instrument panel illumination
75*Radio (start signal)
810*Heated mirrors, switch indicator
920*Fuel pump relay, fuel injectors intake manifold runner control (4.2l)
1020*Trailer tow back-up lamps relay (PCB1), trailer tow parklamp relay (R201)
1110*A/C clutch, 4×4 solenoid
125PCM relay coil
1310Climate control module power, flasher relay
1410*Back-up lamp and Daytime Running Lamps (DRL) relay coil, A/C pressure switch, redundant speed control switch, heated PCV (5.4;), trailer tow back-up lamps relay coil, ABS, Reverse park aid, EC mirror, navigation radio (reverse input)
155Overdrive cancel, cluster, traction control switch
1610Brake-shift interlock solenoid
1715*Fog lamp relay (R202)
1810*Run/Start feed – overhead power point, Electrochromatic mirror, heated seats, BSM, compass, RSS (Reverse Sensing System)
1910*Resrraints (air bag module), OCS
2010*Battery feed for overhead power point
2115*Cluster keedp alive power
2210*Delayed accessory power for audio, power door lock switch and moon roof switch illumination
2310*RG low beam headlamp
2415*Battery saver power for demond lamps
2510*LH low beam headlamp
2620*Horn relay (PCB3), horn power
275*Passenger air bag deactivation (PAAD) warning lamp, cluster RUN/START power
285*SecuriLock transceiver (PATS), PCM IGN monitor
2915*PCM 4×4 power
3015*PCM 4×4 power
3120*Radio power, satellite radio module
3215*Vapor management valve (VMV), A/C clutch relay, canister vent, heated esxhaust gas oxygen (HEGO) sensor #11 and #21, CMC, Mass Air Flow (MAF) sensor, VCT, heated positive crankcase ventilation (PCV) valve (4.2l engine), CID sensor, (4.2l engine), 4.6l/4.2l EGR, electronic fan clutch (4.6l/5.4l engines)
3315*Shift solenoid, CMS #12 and #22, ignition coil
3415*PCM power
3520*Instrument cluster high beam indicator, high beam headlamps
3610*Trailer tow right turn/stop lamps
3720*Rear power point, center console power point
3825*Subwoofer power
39Not used
4020*Low beam headlamps, DRL
41Not used
4210*Trailer tow left turn/stop lamps
10130**Starter solenoid
10220**Ignition switch feed
10320**ABS valves
104Not used
10530**Electric trailer brakes
10630**Trailer tow battery charge
10730**Power door locks (BSM)
10830**Passenger power seat
10930**Driver power seat, adjustable pedals, memory module (pedals seat, mirror)
11020**Cigar lighter, diagnostic connector power
11130**4×4 relays
11240**ABS pump power
11330**Wipers and washer pump
11440**Heated backlite, heated mirror power
11520**Not used (spare)
11630**Blower motor
11720**Instrument panel power point
11830**Heated seats
40130 CBDelayed accessory power, power windows, moon roof, power sliding backlite
R01Full ISO relayStarter solenoid
R02Full ISO relayAccesory delay
R03Full ISO relayHi0beam headlamps
R04Full ISO relayHeated backlite
R05Full ISO relayTrailer tow battery charge
R06Full ISO relayBlower motor
R201Half ISO relayTrailer tow park lamps
R202Half ISO relayFog lamps
R203Half ISO relayPCM
* Mini fuses** Catridge fuses
Administrator
Not supposed to be 12v at the low pressure switch. Its a open/close switch to complete the ground circuit only.
As 85LTD and RS Logan mentioned above, check refrigerant levels and fuses. Might recheck your work at the cluster that you replaced. Something, somewhere may have come unplugged.
Discussion Starter #10
I take the truck to the mechanic and he check all the fuses,pressure relay ac panel and he can’t find it we replace the fuses box and still the same and then we try we the pcm and I don’t do anything, low pressure switch new, new relay, new ac control and we still don’t getting power to the relay box 🤦🏻🤦🏻 But soon he put poner into the relay box the ac start working
Discussion Starter #11
1 - 11 of 11 Posts
