  • As stated in the title, air only blows out of the windshield vents. I can change the speed, and the air blowing doesn’t get too hot or cold but I will charge with Freon after I fix the issue. I’m not sure if the blend door needs to be switched or if there is a leak in a vacuum. I drive a 2004 Expedition 4.6L
Also, there's no need to replace the freon unless it leaks out or you burn out a compressor. It doesn't go bad or break down from normal use.
  • Like
Reactions: Bert
