1 - 7 of 7 Posts
Hi,
Can any one help with the ford fact sheet on how to lock the adaptive shift autos into different shift modes.
hi galaxy
im not sure weather u can change the modes on a adaptive shift unless it it a T _ series
i know you can doo it to them but on a normal XR6 or XR 8 im not sure ill have to investgate this illl let you know
regards john
Galaxy,
Check your manual, it tells you how to it in there. Otherwise check this page and tells you how....
http://203.89.210.6/mainAltFrameset.asp?page=/vehicles/fte_tech_main.asp
Jase
Discussion Starter · #4 ·
Selecting Adaptive Shift Modes
Stop the vehicle, apply Park Brake and turn Ignition Off
Apply Foot Brake and move gear selector to:
1 for Maximum Performance Mode
2 for Maximum Economy Mode
3 for Adaptive Shift Strategy
Turn the ignition On and wait for the air bag warning light to turn off
Move the selector to "R" and wait for the segment on the cluster to confirm the mode selected:
(Not sure if you will see this in XR's only for T series)
PEF - Maximum Performance Mode
ECO - Maximum Economy Mode
ADP - Adaptive Shift Strategy
Return gear selector to "P" and start the engine.
Programmed modes will remain unless the EEC is reprogrammed by the above procedure or the vehicle battery power is removed.
Default mode after battery reconnection is ADP.
Hi all, I am new to this site but have already found out so much information about XR's. My question is this, I have changed my adaptive shift to max performance after reading the posts below. I was wondering if by leaving it locked into performance mode if any harm will done to the gearbox. Should I leave in adaptive shift or not? I prefer the way the car drives in performance mode.
Thanks
It shouldnt. Someone i kno has their tickford fairlane in performance mode 24/ and the car has 255000 and the gearbox has never had trouble. its a good feeling wen it changes gears hard i recon.
1 - 7 of 7 Posts
