Air Bag Codes - '93 Taurus GL 3.0
13939 Views 6 Replies 3 Participants Last post by  tbird100636
1993 Taurus GL 3.0 L single air bag
I am getting a 5 -1 code from the air bag light. Tracking that down, it says:
Internal thermal fuse open (in diagnostic module) due to intermittent short to ground.
I replaced the diagnostic module with a used one from a wrecking yard, same light sequence.
A new diag. module costs over $300.00. Elsewhere I read that the internal thermal fuse is not repairable/replaceable. I would get one a new module (I know that used electronic parts can be bad), but the dilemma is, if there is an intermittent short and I installed a new module wouldn't just "blow" the fuse in it as well and have me out $300. + ?
How do I find the short? How, for that matter, do I find a wiring schematic for the air bag system, like where all the sensors are besides the obvious "collision" one behind the front end grill and the header panel?
Many thanks in advance!
1 - 7 of 7 Posts
PM me your email addy and I can send you the diagnostic routine for the 51 code.
2
Be very careful trying to diagnose this, or do not attempt it. It involves the deployment circuits of the air bags. Read carefully:
Electrical Schematic-Diagnostic Trouble Code 51
Normal Operation
NOTE: The diagnostic monitor contains an internal thermal fuse that is not serviceable. The thermal fuse is controlled by the diagnostic monitor. The diagnostic monitor will blow the thermal fuse whenever a short on the deployment circuits occurs. The thermal fuse does not blow because of excessive current flowing through it. DO NOT attempt to jumper out the thermal fuse with a circuit breaker or any other type of fuse.
WARNING: DO NOT INSTALL A NEW DIAGNOSTIC MONITOR UNTIL THE SHORT HAS BEEN LOCATED AND CORRECTED. IF A SHORT TO GROUND HAS NOT BEEN LOCATED AND CORRECTED, THEN THE SHORT TO GROUND IS INTERMITTENT AND IS NOT PRESENT AT THIS TIME. INSTALLING A NEW DIAGNOSTIC MONITOR WITH AN INTERMITTENT SHORT IN THE SYSTEM WILL RESULT IN REPEAT BLOWN DIAGNOSTIC MONITORS AND REPEAT SERVICE.
The diagnostic monitor measures the voltages at the diagnostic monitor connector Pins. When certain air bag deployment wires are shorted to ground (heavy lines illustrated in the electrical schematic above), the system may become susceptible to unwanted deployment of the air bag(s). The diagnostic monitor senses a short to ground on any of these circuits and helps prevent unwanted air bag deployment by blowing the diagnostic monitor thermal fuse. Blowing this fuse removes all power (battery and back-up power) from the air bag deployment circuits. While the short to ground exists, the monitor will flash diagnostic trouble code 13 or code 14, depending on where the short appears (see code 13 and 14 for more details). If the short to ground is intermittent and temporarily corrects itself, the diagnostic monitor will flash code 51.
NOTE: If the short to ground returns, the higher priority codes 13 or 14 will be flashed instead of 51.
If the Air Bag indicator is flashing code 51 and a short to ground has not been serviced, this means that an intermittent short to ground exists in the air bag system. The diagnostic monitor should be replaced only after service of the intermittent short has been completed.
Some service tips for finding an intermittent short to ground are:
1. Consult OASIS (Restraint Systems service Code 104000) for up to date diagnostics and descriptions of wiring concern locations for the vehicle (VIN number) you are working on. OASIS is updated daily using concern descriptions from engineering and Dealership Service sources.
2. Inspect wiring and harnesses in areas where they pass through or are located next to metal components (i.e. engine compartment bulkhead, body sheet metal, component mounting brackets, etc.)
Code 51 After Air Bag Deployment
NOTE: Diagnostic monitors can withstand several air bag deployments and do not need to be replaced after every deployment. Only replace the diagnostic monitor if it is damaged.
Occasionally, after an air bag deploys, the internal wiring of the air bag(s) may become shorted to the metal housings of the air bag(s). This internal air bag short is detected by the diagnostic monitor as a short to ground in the air bag deployment wiring. Since the diagnostic monitor is still operating immediately after most deployments, the monitor will detect the short and will flash code 13 and blow its internal thermal fuse. After the deployment, as the air bag(s) cool off, the internal shorted wiring may correct itself, therefore the short to ground will no longer exist and the diagnostic monitor will flash code 51. If a vehicle with a deployed air bag is flashing code 51, inspect the vehicle for crushed wiring, sensors, etc. and replace as required. If no damage is found, assume that the deployed air bag was the cause for the intermittent short and replace the diagnostic monitor when the new air bag(s) are installed.
After a short to ground has been corrected, the diagnostic monitor will flash out Diagnostic Trouble Code 51. Diagnostic Trouble Code 51 indicates that the thermal fuse inside the diagnostic monitor is blown and the short to ground no longer exists.
If a short to ground has not been located and serviced (short to ground corrected itself), consult OASIS for potential wiring shorts.
If a short to ground has been correctly located and serviced then replace diagnostic monitor. DO NOT replace diagnostic monitor until the short to ground has been positively located and serviced. Replacing diagnostic monitor before servicing a short to ground will result in repeat service.
See less See more
In Tbird100636's response, as part of the instructions for finding a wiring short in the deployment circuits it mentions this:
What is "OASIS" and is "it" accessible to the general public online?
You need to go to a dealer to get the report based on your VIN.
Thanks, I'll try that...
Bump for another member...
1 - 7 of 7 Posts
