1 - 7 of 7 Posts
After doin a bit of circle work in my ute I had the obvious task of cleaning it up again (refer to Black paint discussion in ute forum), done all the engine bay, routine air filter dust out,What the hell!?
I have a Green plastic Air filter with LPG Only written on it. Oh Sh*t i thought.
I rang the dealer (as i had only had it serviced a month ago) and they told me that the BA's were having a "dust problem" so they fit the LPG ones, Has anyone else heard of this?
Also what is the brand of filters that Herrods use BMC???( I can't remember) as i want to get a better filter.
yep bmc
BluePrint Bandit
good to see;)
hhmmm, im going to check mine tomorrow... and ill ask them when it gets its complimentary service on the 29th. Thanks for the heads up mate.
cheers,
Matt
Just hear the Exhaust!
Never noticed it, then again I only take her on highways and freeways mostly. Never out on a dirt road or anything. Phantom is too much of a pain to maintain...lol. Have a Splitfire cone filter fitted inside the airbox. Does the job quite well believe it or not. Increased overall performance on the dyno by 2-3 horses.
It took me 15 min to change the filter over for a K&N one, then went out the next day and put in the ss cold air intake system, that took 3 hours. Bastard of a job but works very well you just have to seal the thing, other wise it sucks the hot air in from the motor, then went and had a full herrod stainles system put on. Breathes and farts a lot better then b4.
The lpg air filter are made of different materials than the petrol filters,something to do with backfires(in the event it would happen)on lpg system.
Warning: Constant drifter
its not true at all. i work ford Range Ford in perth and it is not a TSB. I work with BA's all day.
1 - 7 of 7 Posts
