1 - 8 of 8 Posts
I
Just a heads up, my stock AIR pump just froze up at 257,000 miles. Getting
it out was easy enough putting it back in was another story. It didn't give
my much warning either, just started making noises last night coming home
from work, and seized solid this afternoon as I was heading in tonight.
Happened right in my driveway so I just blew off a vacation day to work on
it. Not too expensive, just a pain.
P
Discussion Starter #2
On Wed, 01 Feb 2006 06:56:10 GMT, "Ironrod" <[email protected]>
I have to do that too. Why was it hard to put back on? Any tips?
"But now is the time for the younger men to lock in rough encounters,
time for me to yield to the pains of old age. But there was a day I shone among the champions."
Homer, The Illiad, 23.715-719 (800 BC). King Nestor of Pylos.
I
In order to make life easier don't try to work around the alternator, just
take it out so you can get to the hose clamp and the upper bolt which by
some strange coincidence just happens to be slightly longer than the space
between the bracket and the fan shroud. You will need to put the car up on
jackstands to get to the lower attachment point which is conveniently
reversed (facing away) and inaccessible if you are using a standard
ratchet.(I wound up using an offset boxed end wrench.) Once both bolts are
removed the unit will just drop out, so make sure you don't leave any
important parts of your anatomy under the car. Once removed you will
discover that you need to transfer the pulley from the original to the
replacement unit. Loads of fun trying to break lose those three bolts that
haven't been turned since the car was assembled. (I used two ratchets, one
set to tighten the other to loosen, you can get two of the three bolts off
pretty easy this way, have fun with the third one, unless you remember to
break lose all three before you begin removal.)
Upon reinstalling the pump you have to put the top bolt in first, (trust me
on this) but the pump will only go in from the bottom, so you have to
balance the pump on the subframe within arms reach from the top, (did I
mention your car is on jackstands?) reach down between the brackets and the
fan shroud and try to lift the pump into alignment with the holes in the
bracket, (Which you can't see from the angle you are working.) and with one
hand holding the pump in perfect alignment try to get that oversized bolt to
start in to the hole cast into the pump body (Right about now you discover
that the replacement pump is 1mm longer than the original.) Your fingers
will eventually tire, you will let them relax the pump will crash to the
ground and you get to repeat the process. Eventually I figured out that the
bushing pressed into the bracket can be pressed back out (using a decent
size channel lock pliers) so you can make room for the new pump.
If you try to avoid all the trouble of lifting the pump in to place from the
top by anchoring the pump using the bottom strap first since you are already
down there anyway, you will discover that the strap will quickly loosen and
rotate about the single bolt screwed into the block causing alignment
problems.
"patricktee" <[email protected]> wrote in message
news:[email protected]
Getting
give
on
P
On Thu, 02 Feb 2006 06:45:06 GMT, "Ironrod" <[email protected]>
wrote:
Great, thanks. i guess that means I will let my tenant do it. He is
always broke and looking for work. I will supervise. My replacement
has the surpentine pulley already on it, so that part will help
anyway.
A Dealer tech told me the secret to these cars in his opinion after 20
years of working on them is an air ratchet. If you can't reach it
with that, you are doing it wrong. I don't have one, but it helps me
to visualize the process anyway.
>problems.
>Getting
>give
>on
K
"Ironrod" <[email protected]> wrote in message
: Just a heads up, my stock AIR pump just froze up at 257,000 miles.
Getting
: it out was easy enough putting it back in was another story. It didn't
give
: my much warning either, just started making noises last night coming home
: from work, and seized solid this afternoon as I was heading in tonight.
: Happened right in my driveway so I just blew off a vacation day to work on
: it. Not too expensive, just a pain.
You're telling us that the damn thing only lasted a measley TWO HUNDRED AND
FIFTY SEVEN THOUSAND ???
*Sigh* what a doggone shame.
;¬D
KJK
I
They just don't build high quality stuff any more.
"KJ.Kate" <[email protected]> wrote in message
news:%BeFf.71492$C%[email protected]
> Getting
> give
home
on
AND
> ;¬D
> KJK
P
On Sat, 4 Feb 2006 21:53:14 -0600, "KJ.Kate"
>Getting
>give
I lucked out on mine. I loosened the surpentine, put a wrench on the
pulley to get it moving a bit and viola. Course mine only has 43,600
miles on it, but it is an 85 LX.
>;¬D
>KJK
K
Man you got that right. Good thing you get to replace it with one that is
likely built in China. Now it will be good for at least another year or so.
KJK
: They just don't build high quality stuff any more.
: "KJ.Kate" <[email protected]> wrote in message
: news:%BeFf.71492$C%[email protected]
: > "Ironrod" <[email protected]> wrote in message
: > news:[email protected]
: > : Just a heads up, my stock AIR pump just froze up at 257,000 miles.
: > Getting
: > : it out was easy enough putting it back in was another story. It
didn't
: > give
: > : my much warning either, just started making noises last night coming
: home
: > : from work, and seized solid this afternoon as I was heading in
tonight.
: > : Happened right in my driveway so I just blew off a vacation day to
work
: on
: > : it. Not too expensive, just a pain.
: > You're telling us that the damn thing only lasted a measley TWO HUNDRED
: AND
: > FIFTY SEVEN THOUSAND ???
: > *Sigh* what a doggone shame.
: > ;¬D
: > KJK
1 - 8 of 8 Posts
