Hi,
I've got a problem with the fan in my EF. When I turn the AC on, it will only blow cold air when it's in the off position, or the "Boost" (If I put it to anything else, it works for maybe 10 seconds then shuts off). My mechanic said it's a common problem with the fan speed resistor. He said to pull it out and get all the crap out of there to fix it. I pulled it out over the weekend, and couldn't see any leaves or anything in there. I tried sticking the vaccum cleaner in there, but it's a pretty small hole. To test whether it worked or not, I had the resistor sitting outside of where it;s supposed to, and the problem still occured. In the process of pulling out the resistor, I snapped it where one of the screws holds it n, so I am going to replace it. Would replacing it also solve my fan issues? If not, does anyone know what else could be causing my fan to shut off
