ok first you all know the auto trans is bad.. im not sure wtf is wrong with it.. it jerks into gear. it wont drive until it gets to 2-3k rpms. after driving a considerable amount of distance, it will heat up and start spewing trans fluid all in the engine bay. then it wont fully shift into third and final drive.. it will just rev up. next problem? half of the time it wont start. i replaced the coil and plugs wires and all.. still does it.. now. if i play with the wires leading to the coil it will start.. that means one of two things. the coil is bad agian, and it is not making a clear connection to produce enough spark.. next problem? after about a min or so. the engine will start making popping noises, like through the intake. its not the intake, its a fuel/electrical problem, i think. as it reached 3krpm it will start doing it, i pulled a code 0320 and 136
disrtibutor speed malfunction or something. and o2 sensor. now could it be that i need to replace the main state in the distirbutor. also the place where u tighten the belts. the bolt broke out of there.. could that be creating the problem..
thats about all the problems i got for now.. i hope.. anyhelp will be appreciated..
