Ok so far I have cleaned all the old equipment. I have 2 very nice looking spindles loaded with rotors and calipers. I had a real bear yesterday. I found out that the proportioning valve used on the 70 mustangs was part of the distribution block. I looked on a bunch of newer cars that I had been told had proportioning valves I could use, but I never found it. I just may not know what to look for. I ended up purchasing a Wilwood valve new from the local parts store. Cost $50. I am doing my best to keep my existing tubing and distribution block. Spent all day running around trying to find adaptors to let me do that. I am working on 2 options right now on master cylinders:
1 67-70 mustang with power disk brakes
2 74 maverick with nonpower disk brakes.
I have been told that both of them work by different people. My first attempt will be witht the 67-70 setup as if I later decide to add power to the unit I will be ready to go.
I don't know what happened yesterday, but nothing worked as it should. I drove 65 miles in town to different stores looking for adaptors. Today I dropped in discount auto parts (I usually try to avoid them since my last fight with them over a core they would not accept because the box was damaged). Lo and behold they had prefab tubing with different size fittings on each end that would work for my 67-70 mustang master cylinder. I just had to get 1 adaptor (the only one they stock evidently) and it worked. I was able to also get 1 tube that worked with the maverick master cylender and then got 2 tubes that had the correct fitting I needed on 1 end and something I didn't on the other. I then found a local auto shop that could cut and flair the lines for me (making one that I needed). He was waiting on a drum to turn so he did not even charge me! Got the tubing bent, proportioning valve tenativly positioned, and just need to make the braket for the proportioning valve to be done with that part. I will be stripping off the old spindels tomorrow and starting work on the upper control arm relocation.
Will update again soon!
